summarise for weightages
10 replies [Last post]
sudheesh TR
User offline. Last seen 11 years 36 weeks ago. Offline
Hai Guyzz,
I have assigned man days for different categories as resouces. Now i need to summarize the progress percentsge
based on these weightages, also i need to show the same on the summary bar. What i have been doing is, first export the weightages to excel then calculate the percentage in exel itself but i was not able to show it in the P3 layout. So i will highly appreciate, if anyone could advise me in this.
Pranab Kumar Deb
User offline. Last seen 3 years 25 weeks ago. Offline
Dear sudheesh,
Without deleting the resources you cannot have the effect that you want.
Maybe you should see
View>resource profile
select the "Manhours" resource from there .
Hope this helps
regards
pranab
sudheesh TR
Dear exofo,
i believe i m not clear to u.
exofo Ng
User offline. Last seen 16 years 17 weeks ago. Offline
Just modify and select the resource u want.. that it and run..
sudheesh TR
I have many resources in my dictionary. also i cant delete any one of these resources. Can i make a layout based on some particular resources and summarize the same. Please explain if u know...
Sudheesh
sudheesh TR
Sudheesh
exofo Ng
layout by resource mean u need to assign a unique resource name or ID. these could be in term of disciple work or system works. then just use a summary by resource, then run it.. eg Mechanical works, Piping works, electrical works etc..
sudheesh TR
But i dint underastand what u mean by create a layout by resources, Thankful if u could explain it to me. I can use excel but i wana know is there any method to do it.
sudheesh
Christian Adrian ...
User offline. Last seen 5 years 17 weeks ago. Offline
Sudheesh
I would suggest that you create a layout by resources and then summarize it, perhaps that is what you have in mind otherwise just use the excel...
sudheesh TR
Thanks for ur reply. But i hope u dint get me. If i summarize by resources it will take all the resources including material without considering their units. Instead i need to summarize based on some specific category of resources only, like man hours..
exofo Ng
Have u try using summary by resource report? At least it give you a layout of waht u are doing in excel.. save time
