Cost Loading Issues Pls Pls Help
Pat Gaughan
User offline. Last seen 16 years 15 weeks ago. Offline
Hi I am at my wits end with attempting to cost load activity bars correctly I have tried everything.
I am simply wanting to assign an amount of money to an activity, then when this activity is updated for it to update the spend & remaining budget accordingly.
e.g. if I have an activity which is 10 days long and has £10k assigned to it, if this activity were 3 days (30%) complete I want it to then show £3k spent with £7k remaining. I have created a resource called £ and can get it to show the original amount but as soon as I move the start date, or update the durations, % complete etc it amends the figures & gives me random figures linked to the units per day etc etc
Can anyone help as at the moment I am manually working the figures out & each time I move the data date recalculating the spend & remaining!!
Muhammad Zeeshan ...
User offline. Last seen 12 weeks 5 days ago. Offline
Check budget quantity how many you are using per day cause it might producing wrong data
check if its drivien or not
check the resource value again
go in Tabular report from tool produce resource report and see
Please let me know if it solve your problem or not thanks
David Kelly
User offline. Last seen 2 years 13 weeks ago. Offline
Pat,
Post the settings you have in "Tools: Options : Autocost rules"
What "Activity type" are you using
Do you have service pack 3 loaded
