Problem in fliter running
Sinan Fahmi
User offline. Last seen 10 years 4 weeks ago. Offline
Hi my freinds,
i faced a problem when i am going to run filter i got a message "proj environment is too long" and before that the same filter was running without any problem.
i need your support in the case
thanks
Steven Oliver
User offline. Last seen 12 years 34 weeks ago. Offline
Not in P3, you wouldnt.
Tom Howard
User offline. Last seen 9 years 45 weeks ago. Offline
As you found out, it is related to the length of characters in the file path. Moving it up the hierarchy will solve it, however you may have a programme directly in the C:Drive called "thisisaverylongandstupidlynamedprogrammewithlotsofcharactersrevision1draftprogramme" that displays a similar problem
Sinan Fahmi
thank you my freind
it working now
thak again
Ashraf Jahangeer
User offline. Last seen 9 years 19 weeks ago. Offline
Is your project in sub-sub-sub directory.
Try to meve it up and then try running the filter.
Ashraf
