Importing from MS Project to P3e
Davie Ross
User offline. Last seen 12 years 7 weeks ago. Offline
Is there a restriction on the number of tasks that can be imported from MS Project to P3e.
Davie Ross
Thanks for your help I think the problem is RAM. I have managed to import 5000 activities at a time no problem.
Alex Wong
User offline. Last seen 11 years 35 weeks ago. Offline
Groups: TILOS
The quick answer is NO
But... you know that is coming...
In P3e, it does drive a lot of resources especially if you use Oracle or SQL server to drive P3e. As a result, the number of importing or exporting is very dependent in the Memory. Both virtual and Physical Memory. My suggestion is you must at least have 2 G memory (RAM) to operate P3e
Ideal case is 4G
(BTW you posted this in the wrong forum topic)
Alex
Marcio Sampaio
User offline. Last seen 12 years 12 weeks ago. Offline
The maximum I did had 15.000 activities.
I think there is no restriction.
Regards.
Marcio Eduardo.
