Start day & Finish day
6 replies [Last post]
Kris Harry
User offline. Last seen 13 years 13 weeks ago. Offline
Hi Guys,
Can u guys let me know if we can show columns for start day and finish day - example day 120 as start day & day 125 as finish day for a 6 day activity and ow to do it.
Kris
Felis Muhammed
User offline. Last seen 5 years 4 weeks ago. Offline
Sorry guys..2 times i did the same mistake in posting and finaly am replying under this thread
Just check if this is working
Go Data->Custom Data Items (CDI)
Add 3 CDI
1) Name-ORDD , Type-S, length-7, Description-Ordinal data date
2) Name-ORES , Type-N, length-7, Description-Ordinal ES
3) Name-OREF , Type-N, length-7, Description-Ordinal EF
Go Format-> columns
Add the 3 CDI to display on the view
Go Tools->Global change-> Add
In the ‘then’ statement add ORDD EQ your reference date (use calendar from list)
Trial run to see if it worked as per your wish and then run
Go Tools->Project Utilities->Export
Add new
Include “Activity custom data items” to the list
In the Format tab type the name of the file with location
Select type as [.DBF]
Run
Go-Excel
Open the exported DBF file in excel
Format columns ORS & ORF in number format
Use formula
ORS= ES-ORDD
ORF=EF-ORDD+1
Drag down the formula columns till the last activities.
Copy and paste the edited columns as values only.
Save the dbf file & exit (should exit)
go p3->Tools->Project Utilities->Import
Enter the name of the exported file with extention [.DBF]
Run
This is manual method and not dynamic. Donno if some other easy methods are there. Any way back up b4 running. Welcome your comments
Felis
shamail shardan
User offline. Last seen 18 years 11 weeks ago. Offline
Kris,
From my side, i think its not possible, if you could do it, plz let post the method.
Kris Harry
Felis
If it’s Custom Data Item (CDI), it will not be a calculated item and I cannot get the start day and finish day (for early and late dates) for various activities of the project.
Kris
Felis Muhammed
Parves..
Is that Custom Data Item???..if so, Kris u can find it on Menu->Data->Custom Data Item. Using that u can make columns for showing customised data. Think it is datailed in P3 help.
Kris Harry
Thanks Praves,
I’ll try what u have suggested. What is CDI. Can u give the steps for the global change u are suggesting.
Kris
Praves Suppa
User offline. Last seen 1 year 51 weeks ago. Offline
Hello Kris,
Global change & CDI could help you for ordinal dates showing..
Set CDIs for ordinal date of Staring Days and Finishing Day
Run global change for...
STARTDAY Equal ES - (the beginning day of the year.. ie year 1999 you have to choose 31 Dec 1998)
FINISHDAY Equal EF - (the beginning day of the year.. ie year 1999 you have to choose 31 Dec 1998)
Maybe a little help...
Praves
