Global Change...
7 replies [Last post]
John Duterte
User offline. Last seen 19 years 3 weeks ago. Offline
Hey guys!
I’m a beginner of Primavera Project Planner. Is their anybody who can help me how to perform global changed. Like for instance I have this Activity ID.
AB0010
AB0020
AB0030
AB0040
AB0050
I want to change the first 2 digits in to CC. So, that my activity ID will become like these.
CC0010
CC0020
CC0030
CC0040
CC0050
Looking forward for your assistance. Thank you....
regards,
John D.
manulal inasu
User offline. Last seen 18 years 50 weeks ago. Offline
Hi John,
You are welcome.
i think what ronald suggested is better method.
all the best.
Manu
John Duterte
Hi Manu!
Thanks again for your help. It’s work....
regards,
John
Mohd Mahd
User offline. Last seen 16 years 49 weeks ago. Offline
i was wondering, is there any problem to use copy/past? i am not using golbal change unless no other way.
manulal inasu
Ronald,
You are right. Thats a better method.
Manu
Ronald Fisher
User offline. Last seen 5 years 20 weeks ago. Offline
Even better, why not try this:
Using the Substring() function and the Ampersand sign, type in the second box down from the top
ACT EQ CC & SS(ACT,3,8)
works all the time
John Duterte
Hi Manu,
I really appreciated you immediate response for my question. Right after this reply I will try that solution and will inform you if it’s works..... once again thanks a lot
regards,
John
manulal inasu
I shall give you a solution for this.
It is a simple one, which came to my mind as soon as I found your question. Normally I do this type of changes after exporting the file to excel.
The condition for my solution is that your Activity Ids should be having same number of characters.
Go to Tools>Global change
The logic is
IF Activity ID contains AB
Then New Activity ID = CC+ Third to last characters of the present activity ID.
Assuming that your Activity ID has 6 characters, it should be
IF ACT CN AB
THEN ACT EQ CC & RIGHT(ACT,4)
Everything except RIGHT(ACT,4), you will get from the drop down list. RIGHT(ACT,4) you will have to type.
Manu.
