wbs problem -urgent
10 replies [Last post]
John peter
User offline. Last seen 19 years 47 weeks ago. Offline
I have made wbs for a project as under:
1. Construction of Building
2. Phase 1
3. phase 2
4. Externat Works
My problem is that when I organize Level I with TOTAL the Final date is only shown of WBS 1,2 and 3 without Externatl Works Final date?
Why this happens? Why External Final date is not shown in Level total?
Please suggest me a way so that Level cover whole 1,2,3 and 4 wbs dates:
Its urgent plz
Frank Borcherdt
User offline. Last seen 7 years 36 weeks ago. Offline
Can also update activities using Global Change i.e. SS(WBS,x,y) where x is start position including the separators and y is length.
To update the dictionary see knowledge base article 200252492644 and use Project.xls to export the WBS codes and tiles, then massage this to conform to a previously saved activity code format and then import the activity codes and titles.
Work in a copy or make sure you have good backups before you start.
Steven Oliver
User offline. Last seen 11 years 39 weeks ago. Offline
There are some spreadsheets (activity.xls) provided with the P3 installation CD, which with a bit of tweaking would let you do this.
HTH
Dayanidhi Dhandapany
User offline. Last seen 3 years 21 weeks ago. Offline
Dear John,
Send a copy of your program to plannerdaya@yahoo.com, let me have a look.
Daya
Shahzad Munawar
User offline. Last seen 9 years 16 weeks ago. Offline
Hi John
In my view your WBS coding and defining is not correct which needs to be reviewd that’why when you organize, it does not cover the FINAL date of whole project.
Moreover send me your copy of P3 file for correcting this error.
User offline. Last seen 21 hours 11 min ago. Offline
Try organizing first by Project with totals then by WBS. In this way (organizing by activity codes) you make sure you are adding a level above all WBS codes, totals will roll up to the project level. If this works then check on your WBS structure.
Jaco Stadler
User offline. Last seen 17 years 44 weeks ago. Offline
Have a look at your wbs Structure I think the problem is there.
Standard P3 setting will not allow this to work correct. (10)
Data - WBS - Structure
Also remember to look at organize and total at the different levels
MK TSE
User offline. Last seen 4 years 11 weeks ago. Offline
(Sorry for the duplicated postings since a book falls on the keyboard when I editing.)
Consider the WBS as follows: -
1.1 Phase 1
1.2 Phase 2
1.3 External Works
MK TSE
According to your listed, all 4 items are in Level 1.
would you mind list the WBS value against the item for further details
MK TSE
would you mind list the WBS value against the item for futther details
MK TSE
would you mind list the WBS value aginst the item for futther details
