Layout import not working
Akhileshwar Sharma
User offline. Last seen 5 years 10 weeks ago. Offline
I imported a layout and used that on two projects, but its working on one of the projects and not on other.
I'm not able to use custom column like other and while rearrangement its not showing the imported items.
thanks,
Akhileshwar Sharma
User offline. Last seen 1 week 2 days ago. Offline
User offline. Last seen 16 weeks 6 days ago. Offline
if you have codes in that layout it will only work with the project that the codes were created in.
User offline. Last seen 40 weeks 3 days ago. Offline
If your layout uses activity codes or UDF fields then it will not work because they are referencing field ID's from a different database that wont exist in the destination database. You will have to rebuild this part of the layout manually.
