Resource Loading
christopher redillas
User offline. Last seen 7 years 4 weeks ago. Offline
Hi anyone can help me regarding the subject matter.
I got the xer.file (P6) from our subcontractor with resource loading. however, when I importing the s/c schedule to my P6 the resource loading does not match on his resources. What i'm saying is he has a foreman, mason, carpenter but on my schedule (importing from his xer.file) it doesnt show its different resource is loading.
can anyone advise me how to do this? by the way i'm using P6 version 16.1.
chris
D Artagnan
User offline. Last seen 2 years 44 weeks ago. Offline
User offline. Last seen 9 weeks 6 days ago. Offline
possible 2 solutions
problem#1 you do not have the proper rights to import resources
solution get the proper rights
problem #2 your setting option when importing is set to do not import
solution during the import process when you get to Update Project Options select modfiy
in the second section under Data type: Global in the action column cahneg al lof the setting to Insert NEW
Steven Auld
User offline. Last seen 35 weeks 5 days ago. Offline
Chris,
On the XER Import, check the Update Project Options to see what settings are being applied when you import the xer file.
Available Options are:
  • Do Not Import
  • Insert New
  • Keep Existing
  • Update Existing
It may be that this is set to Do Not Import for the Resources.
Steven
