MEP Sequence
Project Planner
User offline. Last seen 10 years 15 weeks ago. Offline
I need the sequence of work and relationship for the following Electrical activities
Embedded Conduiting in the Floor Slab
Conduiting in Blockworks
Installation of Trunking
Install Cable Tray
Wiring for Lighting
Wiring for Power
Wiring for Fire Alarm
Wiring for Emergency Lighting System
Dressing & Termination of Fire Alarm
Wiring for IP CCTV
Dressing & Termination of Emergency Lighting
Wiring for SMATV System
Dressing & Termination of SMATV
Wiring for Structured Cabling
Wirng for BMS
Dressing & Termination of Structured Cabling
Dressing & Termination of BMS
Dressing & Termination of CCTV
Uninteruptable Power Supply (UPS)
Central Battery System
Installation of BMS
Thanks in advance
User offline. Last seen 1 week 3 days ago. Offline
conduit, wire then terminations
in slab would be first
then the highest component in the ceiling
then any in-wall work
User offline. Last seen 31 weeks 2 days ago. Offline
Hi Project
That is too much detail.
You need to split the MEP into 3 tasks - Ducting > Pipework> Containment.
These are place vertically in risers and horizontally in ceiling zones and / or floor zones.
Cables are placed in the containment after weather tight conditions.
IT cables have seperate containment and must not be placed close to HV / LV cables.
