mep sequence in building
Johnny Wee
User offline. Last seen 7 years 13 weeks ago. Offline
Groups: GPC Qatar
just share your ideas,need to complete the following:
electrical
wall:
after blockwork chasing/marking,we can start for conduiting and g.i. box and db box then close by plaster.. then we install wiring for light and power..then install/terminate db after light fittings
ceiling:
after blockwork, install hangers then g.i. tray then high level wiring install, then access for ceiling works
a/c
after blockwork, we can start for 1st fix a/c hanger then start ducting / insulation and fcu and chilled pipes installation in parallel, then connect line bet fcu and duct,then access for ceiling works
after fixing of pipes, testing/commission
Samer Zawaydeh
User offline. Last seen 5 years 39 weeks ago. Offline
Dear Johnney,
It depends on the size of project that you have. Either go by
1st fix electrical: Walls, ceiling and Floor
2nd fix electrical: pulling cables and wires,
3rd fix electrical: sockets, cover plates, lighting fixtures and commissioning.
1st fix Mechanical
2nd fix Mechanical
3rd fix Mechanical: installing fixtures, pads and commissioning,
for big size project, it is preferred that you go by system. For MEP, it can run between 15-25 systems.
Let me know if you have a more specific question.
Best,
Samer
