Group Totals Not Calculating Correctly P6 7.0 SP 4.0
Hi there,
For no reason I can tell, my schedule has suddenly started showing Group Totals in my layout that do not add up correctly, although the activity durations are correct.
From past experience this is usually a calendar issue. I am using a Project Calendar, and the Hours per Time Period checkbox to use assigned calendar is ticked. I am using a 11hr / Day, 7 day a week calendar. Upon looking into the Global calendars, a 38hr week calendar is clicked as a default. Could this be causing the issue? I have done some calculations and it appears that some of the totals are being calculated on a 38hr week, but not in every case.
I know the Global calendar issue was a problem in V6.0 but I was under the impression that the Project Calendar would overide in v7.0. is this the case?
Is there something else I may be missing? The only major work that has been done recently is a colleague removed all the WBS Summary activities from the schedule.
Can anyone provide any way forward?
With Regards,
N
Nathanial Wheeler-Hart 👤 Member for 12 years 8 months
Thank you, my calendar is set correctly via the way you demonstrated.
I forgot to mention that I do not have permissions to change any Globals, and that is why I have not changed the Global Calendar.
With Regards,
S
Shareef Abdul Azeez 👤 Member for 20 years 9 months
Hi Nathnial
Go to 'Enterprise ----Projects'. ....Select your Project
Click the 'Defaults Tab' and change the Calendar that is assigned there.
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
