Level of effort
6 replies [Last post]
Patrick Osakwe
User offline. Last seen 9 years 32 weeks ago. Offline
Hi All. Can anyone please help? I am trying to creat a level of effort activity and have linked it as a SS with its predecessor and FF with its successor both with zero lag. When I schedule, the level of effort activity only shows the start date as start and finish date with zero duration. I have tried putting the number of duration and finish date manually but it goes back to showing start date with zero duration and a negative float of 1 as soon as as I schedule. Please help. Cheers! Patosaks
Gary Whitehead
User offline. Last seen 5 years 32 weeks ago. Offline
LOE is what P6 calls a hammock.
User offline. Last seen 6 weeks 6 days ago. Offline
Hi Gary
Thanks for the information - why not just create a hammock?
Gary Whitehead
Patrick:
the LOE Start date will be the earliest start date of all the SS predecessors of the LOE
the LOE finish date will be the latest finish date of all the FF predecessors of the LOE
Mike:
Patrick is using FF for a LOE (level of effort) activity. These are hamock-type activities in P6 typically used for spreading non-direct resources / prelims, and require FF to operate correctly
Hi Patrick
I can think of no situation in the construction process that requires a FF link.
Perhaps you can enlighten me why you need it.
Patrick Osakwe
Thanks Garry.
In that case the LOE activity will assume the very 1st activity date as it's start date right?
cheers!
Patosaks
Gary Whitehead
Patrick,
The FF relationship needs to be a predecessor instead of a successor.
LOEs should not have any successors.
G
