Change Nonlabour to Labor in P6
Francis Dominic
User offline. Last seen 7 years 38 weeks ago. Offline
Groups: GPC Qatar
Hi all,
Is it possible to change assigned nonlabor to labor with the help of global change / or any other way?
Dominic
Abilash Palakkada...
User offline. Last seen 9 years 23 weeks ago. Offline
You can use global change or resource replacement options, it your resource assignment doesn't have actual values. Otherwise you will have to remove the actual values by keep the record somewhere else and then replace the resource with new one then put the actual as before.
