Non Labor/Labor
Aziz Md Daud
User offline. Last seen 14 years 34 weeks ago. Offline
Is there a setting in Primavera that will allow the resource loading (Historgram) to pickup remaining non labor units instead of remaining labor units? I'm using PL/SQL Procedure and unix scripting to load a csv file from SAP to Primavera. When the data upload is completed the activities with non labor resources was all resides in non labor unit, but when the planners scheduled those activities, the labor unit will be filled with everything with what the non labor unit have.
Upload completed
202
Activities are now scheduled
203
Results
Daniel Limson
Hi Aziz,
P6 can distinguished between 'Labour' and 'Non Labour' based on your inputs on the resources module. When you defined your recources, there is  a column or field called "Resource type" here you enter whether the resource is Labour or Non Labour. When you completed resource loading your programme, you click the icon resource profile on top and right click the screen where you see the Resource Profile, then click "activity usage profile options" a pop out menu will appear and at the right top corner you can see Labour and Non Labour, here you can select by checking what you want to show in your resource profile.
Let me know if you have anymore questions.
Daniel
