Are you planning a big trip? Are you able to remain within your budget? As opposed to simply spending without a plan and then handling the debt for the next few years, use our travel budget template to record your travel expenses. It can allow you to estimate your total travel expenses and see if you'll have the ability to take your trip without going over budget.
21 years 8 months
Member for21 years8 months
Submitted by Rafael Davila on Fri, 2019-06-21 11:37
Anyone knows resource cost vary with time, due to inflation and other reasons such as the one you just mentioned. To model this variation most probably your software has cost periods where you enter how the unit cost escalate with time.
Of course there are other ways to skin a cat but for this purposes this simple method shall be enough. Be careful with cumbersome methods that might yield unexpected resource assignments, keep it simple.
Modeling idle time and idle costs such as the time between activity 1 and 2 is another interesting issue, easy for Spider but wonder about MSP. For fun just add overtime rate while traveling.
Maybe Red Zone Travel shall be increased to 400.00$/hr .... :)
24 years 9 months
Member for24 years9 months
Submitted by Vladimir Liberzon on Tue, 2012-06-19 12:40
If you will meet problems that are hard to solve with the usual project management software tools please post them at "Let's Challenge Spider" thread in Spider Projject forum.
I am still looking for special cases that could be missed in Spider engine.
your answer is quite extensive one, thank you. In fact I have just set my long ongoing task to play around with Spider higher priority, than it had before.
For a short term though, I am still checking whether somebody will come up with some other approach, in compare to what I am using, to calculate travel costs.
24 years 9 months
Submitted by Vladimir Liberzon on Mon, 2012-06-18 16:22
In Spider you can create any number of cost components including those that depend on others and calculated by formulas.
You can also create project reference-books - a set of databases with the corporate norms.
Costs are assigned per unit of time, per physical unit of work volume (cm, kg, etc.), or fixed (independent of time and work).
One of these reference-books can be assignment properties.
In your case you shall define per diems and transportation for each day, plus fixed (return ticket) for each assignment type in the reference-book.
The reference-book may contain many assignment types depending on costs for different travel destinations. Applying reference-book all costs will go into the project model and if you will change them in the reference-book costs assignment costs will be changed for all future events.
It is more complicated with hotel cost because it is not proportional to the work duration. Simple work around - to apply formula.
Enter hotel day cost in the user field (also through the reference-book) and when it was copied into the project model multiply it by (number of assignment days minus one) by formula. I suggest to create separate cost component for hotel cost and the result of formula to be written as fixed for assignment.
Besides, in Spider Project you can create cost centers, grouping cost components. In our case group Travel Cost will be a sum of Transportation and Hotel costs.
Did I answer your question or something is missed?
Is there any other way to plan travel costs, may be not with MS Project, (preferably automatically)?
How others are doing it?
In ideal case I would like to be able to setup some rules, that for instance if I assign Field Engineer to work from Mon to Thu, then the system would also add a cost of return ticket plus 3 hotel costs, plus per diems and transportation for 4 days.
Vladimir, how is Spider doing this?
24 years 9 months
Submitted by Vladimir Liberzon on Sat, 2012-06-09 09:13
"One of the issues my management has is that they don’t like idea of effective rate, as they want to see travel costs separately from hourly rate to be shown in overall “resource usage” table"
Of course!
And certainly it is necessary to analyze not only total cost, but its components, like cost of materials, cost of machines, travel expenses, indirect costs, etc.
6 years 4 months.
6 years 4 monthsAre you planning a big trip?
21 years 8 monthsAnyone knows resource cost
24 years 9 monthsThank you Evgeny.If you
Thank you Evgeny.
Vladimir
17 years 10 monthsVladimir,your answer is
Vladimir,
24 years 9 monthsIn Spider you can create any
17 years 10 monthsIs there any other way to
24 years 9 months"One of the issues my
Of course!
19 years 11 monthsHi Evengy You are on the
Hi Evengy
You are on the right track but instead of a simple task use a summary bar or hammock of the tasks that affect the PM and put the costs on that.
The costs will change automatically as the programme shifts.
