Schedule Basis
I am a newly appointed planner for a green field project due for Singapore, I would like to ask some advice on how to set a BASIS of Schedule. The current program I am adjusting was done in Japan, and I am having a hard time asking the person
due to language barrier.
I would like to ask the more experienced planners on this group to help me define or look for the basis of schedule.
Is it enough that I use the milestones from the client? it was just a completion date of the project. so i am having a hard time...thanks in advance
M
Hi Romil
As the planner on the project you have to have "ownership" of the programme. Therefore you should make a thourough study of the current programme so that you understand the logic and the sequences.
If you cannot understand it  then you must start from the very beginning and draw up a programme that you have confidence in and can support and explain.
Romil Villanueva 👤 Member for 16 years 4 months
Hello Li,
Thank you for the reply, I really appreciate it.
I will consider those suggestions. I am thinking to explain on how i arrived on the current WBS eventhough it was made by a different person....thnks Li...
S
shu li 👤 Member for 14 years 9 months
Looks like we are in the same industry.
I think there are two scenarios here:
1. For Contractual mile stones - what you did or should be doing was simply to demonstrate in the schedule how to get there since the dates are already contractually fixed, by establishing logical links (relationships) between the milestones, and that is your basis for the schedule. Of course the durations you proposed or planned should make sense to experienced reviewers.
2. For milestones your PM created as a proposal for payment purpose (normally) - you will have to have a discussion with your PM on his intention how to run the project. Then you'll have to try to justify according to those intended milestones which often carry commercial implications. Eg, Equipment on foundation linked back to its delivery which linked back to PO placement date. Then you can tell the client the basis for such milestone is that you intend to place PO on a certain date and its lead time is that much and that's how you come out with the milestone date for that equipment on foundation date.
Hope it helps.
Cheers.
Li
S
Shah. HB 👤 Member for 17 years 8 months
Hi Romil Villanueva
To build the schedule ( Base development for schedule ) you need to relay on the following documents
  1. Main/general/Prime contractor program ( if you are subcontractor )
  2. Contract documents
  3. Issued construction drawings and specifications
Shahul
hello shahul, actually before i came to my post, the current PM already sent a draft of the schedule for an EPC schedule of a petrochemical facility, so i had no choice but to use the current program and develop it to a more comprehensive schedule. but I was informed that they require me to explain the basis of the schedule that I did not initiated. that is where my problem is.....I feel I just cant say I am following the Milestones of the previous program that the PM submitted while I was not in my post yet.
Featured Partner
Mattvtek
Gareth Evans
PP Admin
Rajkamal Tangirala
Rahul Kumar
blake333_
Jeamiell Ostrovsky
Hamzah Ahmed
Quinton van Eeden
Sunchana Johnston
