Critical Path Change
AB Timo
User offline. Last seen 9 years 48 weeks ago. Offline
Hello All,
I have just come accross an issue that i never faced before.I have Planned a project and after finalizing the baseline when I updated it on the current data date,The critical path has transfered to Non.Critical.Now there is no critical activity in my Whole project.Anyone know the reason behind this??
Gary Whitehead
User offline. Last seen 5 years 36 weeks ago. Offline
Next most obvious thing to check is if there is a constraint at the project level.
Assuming you are using P6 (most do), you can check this from Enterprise > Projects. Right-click on your project from the EPS structure and select "Project Details". Go to the "Dates" tab and check that the "Must Finish By" field is blank
If it's not this, calendars would be the next thing I'd look at.
AB Timo
Thanks Mike for The Reply.There is no constraint in my Schedule.I have checked all activities.
User offline. Last seen 10 weeks 6 days ago. Offline
Hi Faiz
There could be any number of reasons but the most common is that you have some Must End By constraints.
Remove ALL constraints and reschedule.
MikeTestro
