Difference in Orginal duration
Arun Vasanth
User offline. Last seen 6 years 17 weeks ago. Offline
Groups: GPC Qatar
Dear  Friends ..
I am facing a problem in  P7. I prepared base program and updated.while updating the program the orginal durations in
different WBS Levels  are different .Is there any solution .Please help
Arun
Arun Vasanth
Groups: GPC Qatar
Hai Artagnan I updated Program Manually.. Regards Arun
D Artagnan
User offline. Last seen 3 years 17 weeks ago. Offline
Arun,
How did you update the program? Manually or some external application such as excel or SDK?
D Artagnan
Arun,
Maybe it is because WBS duration is a calculated value (*) and not a fixed entry is why it behaves in this way.
I can think of two workarounds.
Use global change and store original duration as a user defined field, in this way it will be frozen at the activity level as well as at the WBS level, verify on this as I am not a P6 user, I am applying what I recall from my previous use of P3e, P3 and SureTrak.
Store your initial job as a baseline and on updates display baseline original duration next to current schedule original duration.
Hope this helps.
Arun Vasanth
Groups: GPC Qatar
Hai Friends Any experts to answer my above question???? regards Arun
