Early and late S curves in P5.....
Martyn Coates
User offline. Last seen 6 years 26 weeks ago. Offline
I seem to be having a problem getting the curves from p5
I want the data in excel and want to show early and late curves like you can do in P3 for a project.
There seems to be remaining setting dates etc but I can not see any setting to give the whole hour spread from start to finish (whether actual or not) in the form of an early & late curve.
help
I havent seen any definative guide or help to anyone else in older posts
Nathaniel Alexander
User offline. Last seen 14 years 50 weeks ago. Offline
Martyn
Try the following
1)Report Wizard select Time Distribution Data Box
2)Choose the report - Activity Resource & role assignments
3) Select options
4)Filter as follows - Where Open Status = open
5) go to Time interval Fields and select
--Remaining units - remaining early
--Remaining Late units - Remaining late
then next next till the report finishes
Hopefully this will do the trick
