Types of activities in a turnaround project!!!
6 replies [Last post]
Michael Ojo
User offline. Last seen 16 years 3 weeks ago. Offline
Hi guys, i am pretty new to the industry and i need some help from you guys in the oil and gas sector.
Can you please give me an example of activities involved in a turnaround for onshore platform? Project is corrosion control services in OML 124 Field onshore. Type of work is surface preparation,surface cleaning, blasting and coating.
Michael Ojo
Samer thank you so much! In your opinion, would you say detail activities under each resources(design,process,engineering and so on)for this type of turnaround project could be up to 1000?
Samer Zawaydeh
User offline. Last seen 5 years 33 weeks ago. Offline
Hi Mike,
Yes, I have 10 years in the steel industry. 4 in the extra heavy steel structures. We have done numerous projects for a number of industries and each will have its own requirement.
The high level process is the same, but the details depend on the type of application.
I would be glad to assist at any time.
Best,
Samer
User offline. Last seen 30 weeks 5 days ago. Offline
Hi Samer
That was a brilliant response - I get the feeling you have done this before once or twice.
Samer Zawaydeh
For surface preparation you will need to determine type of surface preparation according to SSSP;
a) Surface Preparation
Sa2 (using mechanical hand held tools)
Sa2 1/2 (using blasting)
Sa3 (using blasting to a white metal degree)
b) inspection
You will need to determine the profile of the surface that you need.
c) Coating.
1) Confirm the coating requirement per project specs.
2) Confirm that the paint material is within validity period.
3) Start using the material; using coats between 50-100DFT each.
4) Take the Wet Flim thickness and DFT for each coat and record it.
5) Upon achieving required DFT, ask for inspection by client. Repeat the above until it is approved by client.
6) Mark and ship the material.
Let me know if you need more information.
Good luck,
Samer
Michael Ojo
Oliver thanks for that reply. I was thinking more of activities under each dept/resources. The activities you link together before you run the schedule. Does it make sense?
Oliver Melling
User offline. Last seen 5 years 3 weeks ago. Offline
Groups: The GrapeVine
You’ve already said what type of activities you require....
