Ken,
Lets first of all presume that your using P5.
That being the case if you create the headers for your codes in a project and then export this to excel, ensuring you select all of the appropriate fields/columns.
You should then be able to populate the excel sheet with a sufficient amount of activities and code them with your codes, and re-import that data.
Also if you are using P5 had you thought about keeping the code at an EPS level instead of a global level - just may save on some clutter for your other users??
RE: Importing Activity Codes
Ken,
Hope this helps
Andy
