ACTIVITIES LOGIC
ulysses garcia
User offline. Last seen 14 years 23 weeks ago. Offline
Groups: GPC Qatar
Dear planners,
Is there any best approach in linking activities to a 3,000 task or more in the new project scheduled in order to avoid pitfalls due to illogical sequences .
Regard, uly
Hazem Rady
User offline. Last seen 14 years 6 weeks ago. Offline
I guess the best way is :
1. divide the project into phases or sub-projects or groups or according to responsibilties or location or whatever criteria you can divide your project to.
3. each phase or group has it’s own inter-relations between its activities.
2. try to make milestones or hammocks at the end of each phase that connects each phase with other phases where possible
3. put them together and you got the 3000 act. together
Gilbert Rayco
User offline. Last seen 1 year 17 weeks ago. Offline
In addition to Ronald & Clive, In my practice a well organize activity coding will certainly helps in logic connection and review. Meaning it should not be too long or too short but simple and easily identified.
Clive Randall
User offline. Last seen 17 years 29 weeks ago. Offline
I agree Ronald
However Uly
Have you allready gor 3000 activities?
If you want to check the logic
Put some progress on the programme and see what happens when you reschedule
Also check activities with no successor there should be none
Check where your critical path is and the sub critical ie less than 5 days float less than 10 days float
Then check your constraints again they should be limited
Its a start to what
I call good housekeeping at the end of the planning function and should remove the bugs before its too late.
Unfortunately most of us dont have the time to do it properly
Ronald Romero
User offline. Last seen 1 year 47 weeks ago. Offline
Uly,
Make a subproject template that your sure of the logic then copy this for the rest of the remaining activities or subproject in your schedule. Also use fragnet with the correct sequences. Im sure those more than 3000 schedule has some redundant activities..
Ronnie
