Primavera SDK - ODBC Problem (MS Access link)
Marc Timberlake
User offline. Last seen 18 weeks 1 day ago. Offline
For years now we've been using an MS Access database to upload Actual Labour units across a portfolio of projects, but recently this has failed due to an ODBC error (likely relating to recent server updates).
When I open ODBC Data Source Administrator within Windows, the Primavera SDK System DSN appears in list but is marked with a comment "The Driver of this 32-bit System DSN does not exist, It can only be removed".
Does anyone know a way to resolve?
Thanks!
User offline. Last seen 7 weeks 4 hours ago. Offline
Higher version of P6 is no longer supported by SDK, therefore if you upgraded your P6 version, your SDK will no longer working. The only option is connect it to ODBC using SQL server instead of Primavera SDK.
david kelly
User offline. Last seen 4 weeks 2 days ago. Offline
Marc,
You are entering a world of pain here. I don't know which of the 64 vs 32 bit issues you are tripping over, but you might not find a solution. If there was just one project, then exporting to Excel would be a suitable workaround. But as I am sure you are aware the Excel update is one project at a time. You might need to buy a third party anything-to-Primavera interface toolkits, like Legare.
