P6.2.1 SDK Installation Problem
7 replies [Last post]
Glenn Dexter Ubaldo
User offline. Last seen 12 years 21 weeks ago. Offline
Hello Guys,
I know this is an IT problem but it seems that our company’s IT team is not capable of solving this problem regarding the Installation of SDK. We are using licenced
P6.2.1 Client but everytime our IT is installing the SDK
it is showing.
(Bad public user name or password. Database Server Error: Login failed for user ’pubuser’.
Cannot open database "PMSDK$PRIMAVERA" requested by the login. The login failed.;)
PMDB & MMDB is working but still we are not successful when it comes to PMSDK
Our Settings is:
DATA BASE NAME
PMSDK$PRIMAVERA
DATA BASE ALIAS
PMSDK
PMDB & MMDB is working but still we are not successful when it comes to PMSDK. Guys your help would be much
appreciated.
Glenn
Jerome Soriano
User offline. Last seen 10 years 30 weeks ago. Offline
Hi Glen,
I need to install SDK and explore its uses, but i have the same problem as u had. Could you send me detailed steps on database configuration? Thanks a lot.
Jerome
Jerome Soriano
Hi Glen,
Jerome
Amit Parmar (PMP)
User offline. Last seen 12 years 23 weeks ago. Offline
What username & password are you using to connect to pmdb$primavera?? The default are :
1) username : pubuser
    password : pubuser
2) username : privuser
    password : privuser
Please check if either of them works for you.
Amit Parmar
Almario Nicodemus
User offline. Last seen 12 years 36 weeks ago. Offline
Hi Glen,
From the above, I tried to configure using the same but can't connect.
Hope you will help  me in this regard ..
Tnx.
Almario
Glenn Dexter Ubaldo
Hello Sir,
Thanks for your quick response, I have successfully istalled it, thank you very much. (Galing mo talaga sir)
Glenn
User offline. Last seen 7 weeks 8 hours ago. Offline
Glen,
There is no PMSDK$PRIMAVERA. It should be PMDB$PRIMAVERA. Run configuration again and use pmdb$primavera instead of pmsdk$primavera and it should be fine.
Scarllet Pimpernel
User offline. Last seen 13 years 34 weeks ago. Offline
"Magaling yan", Siyempre pinoy yan,
In english, yes of course. He is simply is the best this planet have discovered. and the fact remains he shared his knowledge and understanding.
GB, PTL, TY
Scarlett
