Database Malformed error
Phil Bedford
User offline. Last seen 10 weeks 6 days ago. Offline
Morning folks,
I have a Primavera P6 v21.12 standalone SQL Lite database which I was working on yesterday, however this morning I have gone to open P6 and it is giving me a "database disk image is malformed"
Thankfully I did create an xer backup last Friday, so still have the main project available which I have imported to a new DB, however I'd really like to be able to access the corrupt DB.
Anyone know of a way this can be repaired?
Phil B.
User offline. Last seen 50 weeks 4 days ago. Offline
There is a complicated set of steps that Oracle says is a workaround, not a solution. Go to the ORacle support site and find this Doc ID.
Error 'Database disk image is malformed' When Attempting to Open a Project, or 'Catastrophic error' When Logging into P6 Standalone with an SQLite Database (Doc ID 2021648.1)
Phil Bedford
Phil Bedford
Thanks for the suggestion.
I have made a copy of the corrupt DB and renamed it.
Went to connect but sadly had the same error.
Thanks again.
User offline. Last seen 17 weeks 1 day ago. Offline
If you are using SQL Lite and you know where the location folder of SQL Light database is (ex: *.db), try to create a copy of the database and rename it. Then try to edit the database configuration of the rename copy of SQL Light database and connect it. Sometimes it works.
