P6 : error when connect to database.
K D
User offline. Last seen 16 years 26 weeks ago. Offline
Hi everyone.
I install P6 database on Windows server 2003, using MS SQL 2005 Express Edition.
I install P6 client module in Windows Vista.
It work properly for 3 weeks but now when connecting it produce an error:
Bad public user name or password. Database Server Error: SQL Network Interfaces: Error Locating Server/Instance Specified [xFFFFFFFF]. ;
Can anyone help me on this?
THanks in advance.
K D
Hi.
When I turn off firewall on win 2003, it connect successfully. But I can let the server turning off firewall all the times.
Which port should I open on the server.
My SQL express use port 1433 so I opened port 1433 but in vain.
Regard
Dieter Wambach
User offline. Last seen 7 years 50 weeks ago. Offline
This message is, when the connection to the db-server doesn’t work.
- physical: cabling, server down, ...
- wrong adress for the database: name
- wrong connection.
Try to establish a new connection with a different alias name.
Good luck!
