How did Zoltan do this on the P6 output?
J
John Reeves 👤 Member for 13 years 2 months
This is from an example that Zoltan did...how did you/he get just the ends, remaining duration portion red?  Below that is mine, I assume he used a date filter but what filter would that be?  - remaining duration?  Zoltan usually beats people to the answer but I assume others know...
Image removed.
Image removed.
S
Santosh Bhat 👤 Member for 21 years 3 months
John,
Posting Images
the PP forum tools are quite outdated and can't handle images attached into the posts. Another option you have is to save you image as a JPG/PNG file on your PC, then use an image hosting provider to upload, then refernce the image in your post.
For example, you can go to Imgur: The magic of the Internetand you don't need to register or anything, just hit "New Post" and then load the file. You will then see a button for share links and you copy the HTML link and then just paste that here into the PP post.
Zoltans example
Given that we can't see the image, it may be one of the following
1) Split activities
2) Multiple bar styles, P6 positions bars in an order in the Bars lists, so one bar with one colour, might be sitting just above, or below another bar showing the same activity as a different colour. However I'd be surprised if its this as they should all be showing the same dates
3) Roll up of a group where the bars are being shown when grouped.
J
OK, I tried to post graphics and they didn't show up.  Let mw know how to post graphics perhaps but I will describe it...His bars are green except for the ends are red with just the critical days remaining on each.  When I do it, the entire bar is red.
Featured Partner
Patricio_aoa
Philip Assou-Dodji
jeoffrey reyes
markg
Manjeet Yadav
Pan
Tijo Kurian
Zainab El-Beialy
Kamlesh Parmessur
