Is there a way to zoom (increase size) of primavera (other than change computer default)
6 replies [Last post]
John Reeves
User offline. Last seen 15 weeks 5 days ago. Offline
Is there a way to zoom (increase size) of primavera (other than change computer default font).  Like to be able to hit cntl + and have it work or whatever the common commands are?  There is a +/- but that only effects the timescale.
User offline. Last seen 16 weeks 1 day ago. Offline
the work around is to use the xer to P3 converter then bring it into suretrack
David Kelly
User offline. Last seen 2 years 29 weeks ago. Offline
I am on 19.12, Zoltan, and P3 format has gone. Not sure when! I still have a working version of Suretrak. Amazing software for the time. Still very impressive twenty (?) years after development stopped
David I am using P6 version 8.2 amd I can still export an xer file to a P3 format and then read that in suretrack
David Kelly
Not any more. You used to be able to export a P6 file in a format that P3/Suretrak would read. You could then open the file in Primavera Suretrak from 1990, and just do CTRL+ or - to zoom the layout in or out. Worked perfectly
the only work around is to make the row height and text larger
th eonly work around is to make the row height and text larger
