Inactive WBS node
7 replies [Last post]
Alexandre Faulx-B...
User offline. Last seen 3 years 10 weeks ago. Offline
Hello fellow Pplanners,
I understand the purpose of making a project inactive; but, what about making inactive a WBS node when the whole project is active?
Thank you for any advice
Alexandre
User offline. Last seen 2 weeks 4 days ago. Offline
ok that makes more sense dissolving an activitiy DELETES it and ites its predcessors to its successor it is gone so there is nothing to schedule. Making a wbs inactivity gives you the ablilty turn it off and on and make it park of the schedule  is you choose to.
that is incorrect making a wbs inactivie DOES NOT DISSOLVE THE WBS it is still there
I never use it I guess if a wbs elemet is no longer necessary or is placed on hold you can make it inactive.
The only place where I see this being used is if you have a standard template setup for your projects.
Let's say that you have submittals & reviews listed by ALL of the master specification number i.e. electrical is 26.
so you have all of the specification sections listed as a standard in the wbs then for this particular project you do not have specification number 27 communications in your scope for this particular proejct then you can make this particualr wbs INACTIVE instead of deleting it.
I personally would delete it.
you cant make a wbs inactive
