Opening 3 projects and create a baseline of them all
Ron Beechey
User offline. Last seen 4 years 37 weeks ago. Offline
How do I create a single baseline of the 3 projects that reflect the 3 open together?   Is it a baseline for each project and just update it or can I do it all at once while they are all open?
User offline. Last seen 4 weeks 2 days ago. Offline
you can show 3 baselines and the current schedule at the same time
when you select the bars just make sure to put the 3 different baselines on different row numbers so that if the dates over lap one bar is not drawn on top of the other.
Ron Beechey
Thanks all for the help I think I understand the issue now.  I will have to work around the fact that I really can't show all the baselines at once.   I was mainly interested in major milestones committed to by the contractors and having the ability to show the slippage and the downstream effect while having them as stand-alone plans that I just import into to update.
you can have up to 3 different baselines associated with one project.
when you assign a baseline the project can not be open and once it is assigned it wil become hidden from view until your restore it if you decided to do so.
