Why use start instead of early start when filtering
Ahmet Tuter
User offline. Last seen 3 years 47 weeks ago. Offline
In Primavera, they told me that using Start criteria instead of Early start (and then using data date range) is preferred. Why do we not use Early start within a range but not Start?
David Kelly
User offline. Last seen 2 years 37 weeks ago. Offline
The "Start" field will contain the levelled start if you have levelled.  Whereas (as long as you have the correct option ticked in the levelling options) Early Start will continue to contain the forward pass result after levelling. So they can be different.
Tom Boyle
User offline. Last seen 7 weeks 5 days ago. Offline
The Start field is accurate for all activities, while Early Start is only accurate for future activities.
The Start field takes the value of Actual Start when it exists and Early Start when it doesn't.  Early Start never reports an Actual Start date.  Under Retained Logic, Early Start rides the Data Date regardless of progress; under Progress Override or Actual Dates, it is blank if an Actual Start exists.
Makes no difference as long as the schedule is un-progressed or you are only interested in future work.
User offline. Last seen 24 weeks 13 hours ago. Offline
you can use either
