Import Relationships
S
sam dsoza 👤 Member for 20 years
I want to import realtionships from a P6 file 1 (correct relationships) in to a different P6 file 2 (incorrect relationships).
Doing it manually is possible but highly time consuming as I may have to touch 700+ activities.
Importing relationship data from correct P6 file in to incorrect one should be POSSIBLE but I have not set up the import file in a while so not sure whats the best route.
Any pointers in this direction will be appreciated. If there is a post which has already addressed this then please point me over as I could not find a topic addressing my needs
S
Hi Zoltan,
Thanks for the help, it worked for the most part.
While importing relationships, I am getting the following error "Failed to find a matching object for Activity Relationship"
Any idea on how to bypass this one. (FYI -  all activities are present in the schedule)
TIA
Z
you would have to delete the incorrect relationships from project 2 first
thnen export the relationships from project 1 to excel when prompted what to export on choose relationships
after you export the relationships to excel on the file in excel and change the NAME of the first part of the WBS to match the
project id of project 2. THE FIRST PART OF ANY WBS IS ALWAYS THE PROJECT ID
save the fie in excel and import into project 2
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
sairedz25
Ahmed Awad
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
