Total float zero but not on critical path.
Gün Göksu
Hi everyone,
I have a schedule where all dates are entered in days. This is shared on a live server.
I somehow now have a schedule with some activities having a total float of above zero but less than 1.
As a result, on a reset to default F9, some activities show zero float but not critical.
I know of a hundred ways to show these as critical, however, I would like the default settings to show this without any tinkering.
How you would approach debuging these less that 1 day floats?
notable hints are: Floats with 0.11 or 0.10 values, calendars with 9h/d, 5d/w and 10h/d, 7d/w etc.
User offline. Last seen 2 weeks 19 hours ago. Offline
without looking at it I would say that some of your durations are not in whole days turn on the decimals in the durations
to check this look under edit users preference.
Then click on the Time Units tab on the left
under the Durations format on the right choose 2 decimals
also your data date TIME and or your Project Must finish by TIME maybe in correct
and your calendar may not be in whole hours.
also if you have any hard constrained dates their TIMES could be incorrect
to check this go to edit users preference
click on the Dates tab on the left and at the bottom select TIME then check 12 hour
Gün Göksu
Thanks Zoltan for the reply. :)
I have no problems showing these as critical,
I am looking for info on how to tackle the root reason this 0.11-0.10 float is created.
what is the bit of data that causes this.
Thanks again.
Gün Göksu
Thanks again.
go to your Projects directory click on the settings tab
under Define Critical Activities
check Total Float less than or equal to
then on the right hand side put in the number 1 or 0 which ever you prefer
