Data date change, critical path changed?
anissa madewa
User offline. Last seen 11 years 45 weeks ago. Offline
I have a fixed schedule from previous project and I want to use it on another project with exact same activities, relationship, and everything. But when I changed the data date, the critical path also changed. Does anyone know why is this happening? Is this normal?
Ronald Winter
User offline. Last seen 4 years 16 weeks ago. Offline
Anissa,
Oh course that is normal.  The critical path often changes over the course of a project.  If it did not, there would be little use in tracking the entire project.
Delays, low productivity, added work, changed conditions, changed workplans all combine to make the job of scheduling a complicated, rewarding experience.  Good luck!
Gary Whitehead
Anissa,
Two obvious things to check:
Calendars. Changing the data date may have brought some non-worknig time into play on near-critical activities which has made them critical.
Constraints: If you have any constraints in the schedule, the dates of these constraints will not have shifted when you changed the data date. You will have to manually adjust / remove them.
G
