Performance over VPN (P6 v23.12)
Marc Timberlake
User offline. Last seen 24 weeks 4 days ago. Offline
Hi all,
We've recently upgraded our P6 install to v23.12, and have one lingering snag that myself and our IT dept can't solve. I'm hoping someone else here may have had similar and managed to resolve!
While in office, performance is spot on - we can schedule projects fine, and importing of XERs is pretty quick.
While working at home via VPN - scheduling works, but is slow, and any XER imports of a moderate size end up timing out and throwing error codes (relating to the time out, we found). We've investigated via our installation consultants, RPC, and also hit a dead end. IT guys have tried all sorts, and last try was the below:
Oracle dont recommend any AV exceptions other than the standard SQL exceptions which are already in place.
I have however added a firewall rule allowing explicit access to the application ports for VPN users, as thats the only thing left open to try.
Any help would be much appreciated. As we have the EPPM version, we can import via web app at least, but not ideal!
Marc Timberlake
Hi David,
we have one planner who is logging in via a remote desktop (VMWare Horizon), as doesn't have any company IT kit, and has no issue, so it's only those of us that use company laptops via VPN with the issue.
david kelly
User offline. Last seen 4 weeks 4 days ago. Offline
Humour me. Run via a remote desktop, to change the traffic type, and see what happens?
david kelly
david kelly
Marc Timberlake
That's the baffling thing about it.
We previously had v17.2 and it worked perfectly over VPN, and all settings for the VPN (and AV/firewall) are matching.
Difference with our set up versus yours is that we don't open a virtual desktop via VPN, we just use it to connect to company network from home.
david kelly
All I can report is that it works for me! Not sure where this particular client's system is, but not my timezone. Connect VPN Run remote Desktop Select IP Full speed P6 Windows client.
