Looping backwards through a 'For Each' collection
6 replies [Last post]
John Borton
Here is the usual VBA code for looping through all tasks in a project:
  For Each t In ActiveProject.Task
      {code for desired action}
  Next t
This loops through from the top down (as far as I can tell).
Anyone have an ideas as to how I can reverse this and go from the bottom up?
JB
Susanna Kate
User offline. Last seen 5 years 13 weeks ago. Offline
Thanks Tom for the code!
John Borton
// "In "general use," one can't reliably presume a correlation between the ID sequence and the logical sequence." //
Understood.  In this case it's a factory production schedule that by fiat gets used in a particular format over and over so I have pretty tight control on how it's sorted.
Thanks again.
JB
Tom Boyle
User offline. Last seen 18 weeks 5 days ago. Offline
John,
Glad you got it sorted.
In "general use," one can't reliably presume a correlation between the ID sequence and the logical sequence.  Still, as you've explained, this certainly seems to offer a bit of streamlining for that particular (ZFF) issue.
Rgds, t
John Borton
That's it Tom ... THANKS.
The task.count property was the secret and this link didn't list it for whatever reason:
https://docs.microsoft.com/en-us/office/vba/api/project.task
s to its usage, I actually just successfully used it to modify your ZFFImpose function.  I've been creating schedules with tasks such that I needed to loop through multiple times to get all the float out of all the faux-ZFF relationships (programatically constraining one task simply moved the float up to the previous task requiring another run through).
My previous schedule had a known number of these relationship layers (3) so I just looped through your code three times.  Now I have a schedule that the users might add an unknown number and I needed a more elegant solution than my previous clutz.
Going through backwards allows your code to now remove the float as far up the chain as needed in one go-round.
I'm a programming hack, so you might have come up with a cleaner solution, but this works slick as a whistle as written.
THANKS (for both the original code AND the mod)
JB
Tom Boyle
Hi John,  this will do what you ask, though I can think of no good general-use case.  Good luck, tom
Sub BackTasks()
    Dim t As Task
    Dim i As Long
    For i = ActiveProject.Tasks.Count To 1 Step -1
        Set t = ActiveProject.Tasks(i)
        If Not t Is Nothing Then
            'Your Code Here
        End If
    Next i
End Sub
Tom Boyle
[Delete duplicate]
