How to remove the indent and outdent function in MSP
kumar s
User offline. Last seen 9 years 9 weeks ago. Offline
Dear All,
Is there a way to remove the outdent option while taking the print.My proejct manager want to show less gap in the task name column which is appearing because of the outdent option.I know there is option in P6 to remove this while we are taking the print..
please guide if this can be done in MSP also
thanks
kumar s
Thanks Again
kumar s
Hi Johnson..
thnaks a lot.It worked...
Rgds,
Kumar s
Bo Johnsen
User offline. Last seen 8 years 52 weeks ago. Offline
Hi Kumar
I'm not aware if there is such a function, but a quick solution to your problem is as follows:
1) Insert a text user column, e.g. "Text1"
2) Copy the entire "Task Name" column
3) Paste in "Text1"
4) Rename "Text1" as required
5) Hide/move the original "Task Name" column so not visible when printing
6) Print
You could also make a formula in "Text1" so it automatically copied and updated the value of "Task Name", meaning you didn't have to think about copying and pasting every time you modified your programme.
Bo
