How to remove pred & succ relationships with IMPORT ?
6 replies [Last post]
Nicolas Berger
Hi guys, I made an EXPORT to EXCEL and made all changes into EXCEL for a result of removing around 200 redundant relationships which created loops... Actually it seems that the deletion of relationships are not taken into account. Thanks by advance
Nicolas Berger
Yes thanks it works well ;-)
Jaime Linchangco
User offline. Last seen 16 years 16 weeks ago. Offline
Hi Nicolas,
My reply is incomplete.
Step 5, save the file and then import it to your schedule.
That’s it. Done.
Jaime
Jaime Linchangco
Hi Nicolas,
Good day! Yes, there’s an easy and effective way of deleting those unwanted relationship.
Follow these steps to delete specific relationship right inside your Excel (dbf or Lotus 123).
1). Export the successors relationship
2). Create a new column "in-between" the data columns.
3). Name the new column at Row 1 as DELETE
4). Type letter S at this new column to all those Activity
that’s causing your loop or those "unwanted" links.
If you want further details about this very useful steps, go to Help menu, and search "Delete data in Lotus 1-2-3 or dBASE.
Cheers Mate!
Jaime
Christian Adrian ...
User offline. Last seen 5 years 49 weeks ago. Offline
If the suggested steps doesn’t seem to give you the result you expected then doing the conventional way would be the best way... that is to run and print a report of looping activities and then modify it one by one...
Cheers...
Nicolas Berger
Understand, but there is no command in Global change for deletion of relationships...
Gün Göksu
they are not taken into account.
quickest way to do this is this:
0. BACKUP!
1. export all of the relationships.
2. edit the relationships file as you like.
3. delete all relationships with global change.
4. import the relationships.
