night shift activities
kumar s
User offline. Last seen 9 years 15 weeks ago. Offline
dear all
how to filter the actiivtes which is scheduled only in the night shift.
i have taken the calendar as 24/7.
so now i have to assign the activites which is starting in the night shift to the night supervisor.
what is the parameter in the filter to be selected.
thank you.
User offline. Last seen 7 weeks 3 days ago. Offline
Go to Resource Usage view and define a new filter “Resource Base Calendar is Night Shift” where;
  • Field Name = Base Calendar
  • Test = equals
  • Value(s) = Night Shift
It will display only activities with assigned resources whose base calendar is Night Shift. Therefore, in order to identify night shift activities these must already have been assigned a resource with a night shift base calendar. If you want to exclude activities with assigned calendar resource, exclusively a night shift then you shall expand your filter as to exclude those.
You can create a Combination View with a Primary View equal to Resource Usage and a Details Pane equal Gantt Chart, there you can apply the filter on the upper pane and select the activities on the lower pane.
