exporting views
9 replies [Last post]
John Banks
User offline. Last seen 5 years 20 weeks ago. Offline
I’m trying to produce a s curve based on baseline, actual & scheduled work in Project 2007. I’ve produced the correct work table view, showing baseline, actual & schedule. How can I produce my graph from here?
John
Brad Lord
User offline. Last seen 10 years 26 weeks ago. Offline
didnt know i was breaking some law, if i wish to give my number out i will do so
User offline. Last seen 4 days 19 hours ago. Offline
Hi Brad
It is not a good idea to give out phone numbers and email addresses on the open forum.
Please use the private message service to exchange this sort of info.
Brad Lord
john
give me a call
regards
brad
John Banks
Brad
Don’t think that’ll do it. It needs to be from task usage, but, unless I’m looking at the wrong view, the left side of the screen & the table need to copy separately, and there are three rows of data in the table to each task. There has to be a better way than that degree of manual manipulation?
John
Brad Lord
Just copy and paste the values from the resource usage screen into excel with the dates, then select the area and press the automatic graph icon and annotate to suit
Trevor Rabey
User offline. Last seen 2 years 1 week ago. Offline
I am pretty sure I can help, but it just takes so much typing to explain it, especially without seeing it.
Is there any chance that you can send me the file so I can see what we are dealing with?
Mal Leadbetter
User offline. Last seen 11 years 12 weeks ago. Offline
Groups: TILOS
John
As I said, my use of MSP 2007 is limited and I am sure there is someone who may be able to sort this out.
Would the Budget Work Report not give you what you want ?
Sorry I can’t be of any more help
John Banks
Mal
The report is not there. i’ve tried setting it up, but for some reason can’t produce a task usage pivot table which shows baseline work - actual & scheduled appear no problem.
Mal Leadbetter
Groups: TILOS
John
on the tool bar go to < Visual REports> and select the report you require. This will export your info to excel as long as you are using Excel 2003 or later
From my limited use of MSP 2007 so far, I personally think the "Analyse Timescales Data in Excel" macro was better in MSP 2002/03.
