MS Project 2003 - Vertical milestone line
John Matthews
User offline. Last seen 11 years 11 weeks ago. Offline
Other than using the drawing tool to physically put a vertical line through a Gantt chart, is there any other method of putting a vertical line through the chart.
I would ideally like to highlight a couple of key project phase milestones by having a vertical line through the Gantt chart view (similar to the ’current date line’). Drawing a line is okay but I would prefer if it I could anchor it to a milestone in some way but cannot see a way of doing this.
John Matthews
That worked fine in MS2003 also. Thanks for the advice.
James Griffiths
User offline. Last seen 16 years 3 weeks ago. Offline
Hi John,
You should be able to "anchor" your line to a milestone. When you have drawn the line, double-click on it. Click on Size& Position. It’ll give you the options (this is what it does in MSP 2000)
HTH.
James
