Resorce Graph
Hemanth Kumar
User offline. Last seen 1 year 45 weeks ago. Offline
Is it Possible To Show Color Coded Multiple Resource data In a sigle sheet Resource Graph
James Griffiths
User offline. Last seen 16 years 17 weeks ago. Offline
Gentlemen,
You can show multiple resources on one graph!! By using the Analyse Timescale Data in Excel, you can export all the resource data from the Resource Usage or Resource Sheet view. In Excel, you can then convert the data to a Stacked Histogram or Stacked Column. This will give a different colour for each resource, for each time-period.
I did this some time ago. It worked beautifully - but it took a little time. The only real problem is if you have lots of different resource names. The colours then become diffcult to differentiate.
James
Hemanth Kumar
Thank You
