Filtering by Trades Contractor
Dominic Planner
User offline. Last seen 1 year 16 weeks ago. Offline
Hi All,
Is it possibel to filter by trades contractor? I am currently using version 13.0.02.069 of Asta
Dominic Planner
Spot on, thank you gents
User offline. Last seen 13 weeks 1 day ago. Offline
Hi Dominic
You can also filter on the task title by typing *laster* which will then pick up Plasterer - Plastering etc with or without capitals.
You can then add a code to the filter if you wish.
Mike T.
Ben Taunt
User offline. Last seen 1 year 12 weeks ago. Offline
Hi Dominic,
If you set up your project using the default template, you may already have the filter setup for this.  Go to View > Filter > Codes > Which Code? [asks for a code(s)].  You can then chose the trades contractor code library from the list.
If you used a different template without the filters pre-installed, you'll need to create the filter from scratch by going View > Filter > New... and following the wizard.  Check the Help File for more details or contact your local Asta Powerproject support team.  You can then save that as a default filter for a certain view etc.
In v14.0.02 we may filtering by code library even easier - you can now just double-click the name of the code in the project viewer to enable a code library filter of the tasks in the current view(called a Code Breakdown Structure).  This mirrors the functionality we've had for Resource Breakdown Structures since v12.
Hope that helps,
Ben @ Asta Powerproject
