Filtering on Predecessors and Successors
Oliver Johnstone
User offline. Last seen 14 years 36 weeks ago. Offline
Can anyone tell me how to create a filter which will present the direct predecessors and the direct successors to a particular activity.
Carlos Arana
User offline. Last seen 7 years 2 weeks ago. Offline
When inside this P&S view, what’s the quickest way to jump to the pred/suc of one of those activities in the view?
Mal Leadbetter
User offline. Last seen 12 years 2 weeks ago. Offline
Groups: TILOS
Oliver
From an unfiltered view, click on the activity whose predecessors / successors you wish to see.
Then go to toolbar, select view. From the drop down menu select view and from the next drop doown menu you should see an option for Predecessors & Successors. Click this and this gives you your direct predecessors and successors
Knowing (or not as the case maybe) PowerProject, there is probably a shortcut to do the above!
Hope this helps
Mal
