Paste Linking
Dean Grimes
User offline. Last seen 8 years 5 hours ago. Offline
Hi all Can anyone please help me out and give me some guidance. I would like to set up a task pool that could be linked to the main programme I.e. If I was to alter the the task pool durations or operation it would automatically alter the main programme. For example paste linking as if you would in excel. Many thanks in advance for your help
Dean Grimes
Mike. Many thanks for your help
User offline. Last seen 11 weeks 6 days ago. Offline
Hi Dean
You can run a filter on a type of task - say Plaster Walls - and then make all the changes at once.
Dean Grimes
Mike Thank you for your prompt response. The issue that i have is that i am having to produce a number of identical sequences of work which the client seem to be constantly changing, and as i have around 400 of these sequence patterns i am having to change them all individually. Is there any way i can link them to one task pool so that if i change the task pool it changes all of the sequences in the bar chart. I.e. Paste linking in excel (alter 1 and it changes all the other tasks)
Hi Dean - Welcome to Planning Planet
The spreadsheet in the PowerProject table is the same format as excell. You can copy / paste between the two at any time.
I prefer Lotus 123.
Mike T.
