Layout on print preview
Syed Shoeb
Vimukthi
bal aji
Lee Mallek
Viet Tran
Ola Gbotoso
Jaturapit Multongka
Haque Nawaz
EViLL1
Hi Mike
Many thanks for your reply.
I have had to renumber everything again and this time, the column is better fitted to the width of the WBN number and now it prints out with a reasonable sized width column!
I dont know what I did but it now works :)
Christine
Hi Christine
Have you tried to print the chart anyway - sometimes the preview does not replicate the actual printed layout.
Otherwise highlight the column and right click to show properties.
In table definition there is a box showing column width - set this to your required size.
There is also function that sets the column width to fit largest font in Print > Appearance > Spreadsheet > Fit largest font.
With longer text strings you can set the column to wrap the text.
I hope this helps.
