Immigration to USA - how long does it take?
jaasland
Doron El
Erim INANC
gorilpk
Ricky
pinoyplanner
Siddharth Ranadive
Aidar Kurmantayev
Dave Morgan
Hi David,
If you are moving with the US company to the US, then you will be on an L1 visa which is actually better. And depending on the years of experience and your position, most likely you will be eligible for EB-1 category on the green card process. Tha t means you will get your green card on a fast track basis - usually within a year. To initially get a L1 visa processed - it should nopt take more than a month - if it is on a premium processing - additonal 1000 dollars. hope this helps. thanks.
raj
