How good is your country at reporting covid-19 statistics - it is a mess.
User offline. Last seen 7 weeks 6 days ago. Offline
I do not believe Covid 19 could be tacked effectiviely if your country statistics are poor.
Image-027
Such numbers are misleading, 100% positivity rate!
Whoever publishes some numbers without having the necessary information loses credibility.  It is simple if you are incapable of getting the necessary information do not publish any number.
I wonder if the reporting in your countries is this bad.
Some sites such as covidtracking.com do not report misleading numbers.
https://covidtracking.com/analysis-updates/test-positivity-in-the-us-is-a-mess
Image-053
The following is another site again with different results.
Image-030
And another.
Image-032
The difference in reported infection rate among these two sites is abysmal!
Until there is no uniform reporting standard it will continue being a mess.
They say some territories do not report negative results.
  • Puerto Rico does not report negative results for one logical reason: The reported number of patients tested do not represent the same patients included in the reported number of patients tested positive due to a lag between the date the specimen is collected and the availability of test results. Positivity rates cannot be inferred by dividing patients tested positive by patients tested for this reason.
  • I do not mean to say it is not possible to pair same day test results, this would mean true positivity rate will lag several days the day the specimens are collected.
  • It looks like PR figured it out how to estimate positivity rate better than showing 100%, a meaningless value that is not credible.
  • If you do not have the data you shall not report any number, to show 100% is wrong, these "fake news" makes their credibility go down the drain.
