Negative Schedule Variance
Kannan CP
User offline. Last seen 43 weeks 5 days ago. Offline
Is a negative schedule variance indicates that the project will not finish on time?
In my opinion NO. because, as of the reporting period, critical items planned values may be achieved and keeping the completion date on time. meantime few non critical activities may not be started on time, keeping the EV less than the PV.
So negative variance only indicates that the value of work done is not as much as of planned.
Share your opinion
Best Regards
Kannan
Praveen Malik
User offline. Last seen 2 years 34 weeks ago. Offline
Hi Kannan, You are right. Negative SV only means that project is behind, as per the current schedule, on status or control date. It does not give any indication of the future work. For more on variances, you can look at https://www.pmbypm.com/basics-earned-value-analysis/
Patrick Weaver
User offline. Last seen 3 days 16 hours ago. Offline
If you are not doing enough work there will eventually be a major issue -ve SV highlight this.
If you are not doing the right work there is a problem -ve Float highlights this.
You need both sets of information (and their trends) to really understand the situation on a project. See: https://mosaicprojects.com.au/Resources_Papers_117.html
User offline. Last seen 27 weeks 4 days ago. Offline
glad I could help
Kannan CP
agreed and thanks Zoltan..
Kannan
negative float yes
ngeative variance no because there can be float in the schedule that tyou are comparing against.
